last person joined: 11 hours ago
ACS replacement with ClearPass
  • 1.  ACS replacement with ClearPass
    Posted Jun 05, 2014 08:46 AM
    All,
    I have a customer that is looking to replace their existing Cisco ACS server and possibly use ClearPass. They are currently tracking every command that an authenticated user submits on their Cisco switches. Is this even possible with ClearPass? Possibly with Insight?
  • 2.  RE: ACS replacement with ClearPass
    Posted Jun 05, 2014 08:48 AM
    Yes.
  • 3.  RE: ACS replacement with ClearPass
    Posted Jun 05, 2014 09:15 AM
    Troy,
    hope all is well...
    So in order to log all commands that a user enters, we have to first permit what commands we want to allow and then somehow turn on logging on them? We've provided the customer with a PoC CPPM using the canned PoC templates for ACS replacement, but it does not spell out how to do this piece.
    thanks,
    Kevin
  • 4.  RE: ACS replacement with ClearPass
    Posted Jun 05, 2014 09:16 AM
    You do not have to turn on command authorization to log commands. By default it will log all commands once accounting is turned up.
    Once you enable TACACS+ accounting, the logs will appear in the Accounting log in CPPM.
  • 5.  RE: ACS replacement with ClearPass
    Posted Jun 05, 2014 12:03 PM
    On a cisco device you need to make sure you have.
    aaa authorization config-commands
    aaa authorization commands 0 default group tacacs+ none
    aaa authorization commands 1 default group tacacs+ if-authenticated
    aaa authorization commands 15 default group tacacs+ if-authenticated
    aaa accounting commands 15 default start-stop group tacacs+
    aaa accounting connection default start-stop group tacacs+
    Or you will not get all the commands loged.
  • 6.  RE: ACS replacement with ClearPass
    Posted Jun 09, 2014 12:34 PM
    Do we need to do anything in the CPPM enforcement profile to enable accounting? We've added the commands to the switch but see nothing in the CPPM accounting logs.
  • 7.  RE: ACS replacement with ClearPass
    Posted Jun 09, 2014 12:36 PM
    Is TACACS authentication and/or authorization working?
  • 8.  RE: ACS replacement with ClearPass
    Posted Jun 09, 2014 12:40 PM
    Yes, authentication is working.
  • 9.  RE: ACS replacement with ClearPass
    Posted Jun 09, 2014 02:16 PM
    Ok, I can now see the authenticated session and the commands run during that session under accounting. How do we show the commands in the report format as above?
  • 10.  RE: ACS replacement with ClearPass
    Posted Jun 09, 2014 04:27 PM
  • 11.  RE: ACS replacement with ClearPass
    Yes, ClearPass can do full TACACS+ command logging and authorization.
  • 12.  RE: ACS replacement with ClearPass
    I see this would allow us to permit/deny specific commands, but how do we log everything the user does on the switch?
