Activating RF Protect on Existing Wifi Network
  • 1.  Activating RF Protect on Existing Wifi Network
    Posted Sep 26, 2018 09:29 AM
    Hi all,
    Quick question. I have some RF Protect licenses on my aruba mobility master however they are not in use. I have had an active wifi environment for a while and have only just realised this. Am i required rto activate them to the AP's specifically or is there a process for it?
  • 2.  RE: Activating RF Protect on Existing Wifi Network
    Posted Sep 26, 2018 10:15 AM
    How to add licenses is here:  https://www.arubanetworks.com/techdocs/ArubaOS_83_Web_Help/Web_Help_Index.htm#LicenseGuide/install_MMaster.htm?Highlight=adding%20licenses
    Adding a new type of license will require a reboot of the MD where the licenses are applied.
  • 3.  RE: Activating RF Protect on Existing Wifi Network
    Posted Sep 27, 2018 05:23 AM
    Hi thanks for your help, however im not having issues with adding licenses.
    The licenses have been added however all my RF Protect licenses are idle.
    Do I have to specifically apply some command to kick them into use or is this something to do with the AP's?
    Thanks all for your help
