I have a 7005 controller running Aruba OS 6.5.4.6 and would like to utilize the additional wired ports on the bottom of my 303H AP's. How do I turn them on?
Thank you for the quick response. Do you have instructions for doing it via the Aruba OS 6.5.4.6 gui on the 7005 controller?
Google turned up this result for the wired port profile parameters in 6.5 vs 8.x.
https://www.arubanetworks.com/techdocs/ArubaOS_6_5_3_X_Web_Help/Content/ArubaFrameStyles/1CommandList/ap_wired_port_profile.htm
Under your AP Group configuation (where the RAPs are contained), expand the AP folder to expose the available ports. Select the appropriate port (ethernet interface 2, for instance) and you can select an existing wired port profile or create a new one.
