last person joined: 4 hours ago
Active-Active redundancy, Controller configuration is not synchronize
  • 1.  Active-Active redundancy, Controller configuration is not synchronize
    Posted Mar 29, 2016 09:17 PM
    Hi All,
    I have 2 Aruba Controllers in Active-Active redundancy configuration. They are running two instances of VRRP and each controller acts as the primary for one instance and backup for the other.
    I found that the controller configuration are not synchronize so I need to input the configuration twice on each controller. Do I miss some steps or this is a consequences of using Active-Active redundancy?
    Niko
  • 2.  RE: Active-Active redundancy, Controller configuration is not synchronize
    Posted Mar 29, 2016 09:27 PM
    Do you need the capacity of one controller or two? If you only need an n+1, you should make it a master/backup master redundancy:
    You point the APs at a single VRRP instance between the controllers.
    Only a single controller will work at a time.
    Configurations will be synchronized.
    If you need the capacity of two controllers, you need a master/local configuration where both controllers can actively terminate access points at the same time.
  • 3.  RE: Active-Active redundancy, Controller configuration is not synchronize
    Posted Mar 30, 2016 01:04 AM
    Hi Collin,
    If we use master/local configuration, both controler configurations will able to synchronize right?
    niko
  • 4.  RE: Active-Active redundancy, Controller configuration is not synchronize
    Posted Mar 30, 2016 01:23 AM
    Correct.
