Active Directory with Clearpass cluster across multiple datacenter
  • 1.  Active Directory with Clearpass cluster across multiple datacenter
    Posted Nov 08, 2018 02:32 PM
    I have a cluster with subscribers in two datacenters.
    Is it possible to configure Active Directory lookup to perform actions against a dns entry for the data center the authentication is happening from as a primary source?
    Example:
    DNS1 - AD DNS Entry for Datacenter 1
    DNS2 - AD DNS Entry for Datacenter 2
    CPPM1 - Publisher, in Datacenter 1
    CPPM2 - Subscriber, in Datacenter 1
    CPPM3 - Subscriber, in Datacenter 2
    CPPM4 - Subscriber, in Datacenter 2
    A VIP is used between the servers for authentication at Datacenter 1 and a different one is used at Datacenter 2.
    We loadbalance from the controller to authenticate against both VIP.
    Is there a way to specificy, if device is authenticating against VIP at Datacenter 1, it uses DNS1 and if it authenticates against VIP at Datacenter 2, it uses DNS 2?
    Or does this really not matter because the server only polls and caches from the publisher?
  • 2.  RE: Active Directory with Clearpass cluster across multiple datacenter
