Wired Intelligent Edge
active gateway aruba 8325 CX
This thread has been viewed 22 times
  • 1.  active gateway aruba 8325 CX
    Posted Mar 23, 2021 12:57 PM
    Good day.
    Dear, do you know with what command I can see the IP addresses assigned to each vlan as active gateway? The Show Ip interface only shows the IP assigned to the physical box in the vlan, but I need it to be the summary of the Active Gateway IPs.
    Thanks for the help.
    SB
    Sebastian Barreto
  • 2.  RE: active gateway aruba 8325 CX
    MVP GURU
    Posted Mar 23, 2021 06:09 PM
    Hello Sebastian, try to use:
    show vlan (to see VLAN IDs you could be interested in)
    then:
    show active-gateway vlan<VLAN-id> (so if you have VLAN 1100 the command should be: show active-gateway vlan1100).​
    The same command above without the vlan<VLAN-id> option will provide a summary of the Active-Gateway interfaces.
    Other interesting commands to complete the whole picture are:
    show ip route local
    and:
    show ip interface vlan<VLAN-id>
    show ip interface vlan<VLAN-id> vsx-peer
    Davide Poletto
