Hi there,
I'm currently using Mactrac, and it is working fine except for the fact that "Active Sessions" under the guest portal are empty for the user that registered the device.
If I login as admin, I can see the sessions for the devices as active.
Also, if I disable the "Operator Filter" it also shows the devices and sessions. But if I set it to "only show accounts created by this operator", nothing shows.
Any ideia how to fix this? I want the users to be able to check active sessions for their registered devices.
