Active Sessions Management - Reauthorize
  • 1.  Active Sessions Management - Reauthorize
    Posted May 17, 2017 04:26 AM
    I have found and option to Disconnect Guest user and Reauthorize Guest User. What does exactly Reauthorize Guest User? How it works? What kind of profile do I have to addiotionaly configure?
    Thank you,
    Vulpe
  • 2.  RE: Active Sessions Management - Reauthorize
    Posted May 17, 2017 07:18 AM
    Hi Vulpe,
    Please check below guide
    https://community.arubanetworks.com/aruba/attachments/aruba/SoftwareUserReferenceGuides/29/1/ClearPass_Guest_6.4_User_Guide.pdf
    In page 33, it explain in detail, we need to configure Radius CoA.
    Pavan
    If my post address your query, give kudos:)
  • 3.  RE: Active Sessions Management - Reauthorize
    Posted May 17, 2017 07:51 AM
    thanks for you answer. I applied CoA profile, but I got a warning that it is incorrect profile. I applied the same profile to Disconnect option and it was working. Do you have any example of that profile for Reauthorize user?
    Vulpe
  • 4.  RE: Active Sessions Management - Reauthorize
    Posted May 17, 2017 08:30 AM
    Could you please share the screen shot.
    pavan
  • 5.  RE: Active Sessions Management - Reauthorize
    Posted May 17, 2017 07:19 AM
    It issues a change of authorization​.
