AD-join failing to resolve NETBIOS name
This thread has been viewed 21 times
  • 1.  AD-join failing to resolve NETBIOS name
    MVP
    Posted Dec 06, 2017 02:56 AM
    I'm trying to get a clearpass registered in AD but running into some issues. When trying to resolve the NETBIOS name is fails with error: ads_connect: No logon servers
    Clearpass is behind a firewall. I requested that the required ports be opened (according to http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/What-are-the-ports-that-need-to-be-opened-on-the-network/ta-p/175872) but still no luck.
    When I do a packet capture during the join attempt I can see Clearpass doing DNS (and getting answers).
    I can also see CLDAP (udp 389) searchRequest for "<ROOT>" baseobject to the domain server but it appears nothing is being returned even though routing seems ok.
    Finaly I also see some netbios queries (only queries, no answers) coming from both data and mgmt interfaces where I only use mgmt for everything but guest traffic.
    So, what is going wrong here? What exactly is being used to resolve that NETBIOS name?
  • 2.  RE: AD-join failing to resolve NETBIOS name
    Posted Dec 06, 2017 03:54 AM
    It might be worth adding a route to the domain controller (or domain controller subnet) over a particular interface.
  • 3.  RE: AD-join failing to resolve NETBIOS name
    Posted Dec 06, 2017 04:01 AM
    Hi ,
    Generally we see such error message if AD is not reachable, could you try do a testjoin from CLI
    Tests if Policy Manager is a member of the AD domain.
    Syntax
    ad testjoin
    Try join the AD from CLI
    Joins host to the domain.
    Syntax
    ad netjoin <domain-controller.domain-name>
  • 4.  RE: AD-join failing to resolve NETBIOS name
  • 5.  RE: AD-join failing to resolve NETBIOS name
    MVP
    Posted Dec 06, 2017 05:52 AM
    Thanks all, lesson learned, trust your own pcaps over fw guys :P
    Needed ldap, opened only sldap
