  • 1.  AD over SSL
    Posted Oct 13, 2017 07:12 AM
    Hi!
    I´m having trouble with AD over SSL. I´ve created a certificate for the clearpass server from AD CA and uploaded it, also added CA to trust.
    The clearpass server is member of 2 active directories.
    As soon as I choose: "Enable to verify Server Certificate for secure connection" . The source fails.With errormessage: "Can't contact LDAP server"
    But I can use it fine running AD SSL over 636 without this option no problem.
    Clearpass and AD server is in the same subnet.
    Any tips for troubleshooting ?
    Is the connection still running encryptet without this option enabled ?
  • 2.  RE: AD over SSL
    Posted Oct 13, 2017 10:24 AM
    Do you also have the root from the CA that issued the DC cert in the Clearpass trust list ?
    Launching a packet capture on the CPPM node and analysing what is being presented by the DC could be a good thing too.
    Cheers,
  • 3.  RE: AD over SSL
    Posted Oct 15, 2017 01:49 PM
    As said, you need to import and enable the root CA that issued the certificate for your LDAPS. The problem likely lies in here.
    If you like to see the process in a video, check here.
  • 4.  RE: AD over SSL
    Posted Oct 18, 2017 05:33 AM
    Hi!
    Thanks for the tips, I´ve installe the root cert so that wasn´t the problem.
    I´m embarrassed to say but it turns out that the AD-servers where added as sources with ip instead of DNS-name.
    The log details in access tracker showed:  ERROR RadiusServer.Radius - rlm_ldap: TLS: unable to get CN from peer certificate
    Which clued me in. Pretty obious in the end :)
