Adaptive radio management assigned on 2.4GHz
  • 1.  Adaptive radio management assigned on 2.4GHz
    Posted May 29, 2019 04:26 PM
    Hi
    I have 3 x IAP-205H with an Instant Controller but the 2.4 GHz channels used by all 3 IAPs are 11 on each IAP, I have had to use administrator assigned to use the non-overlapping channels (1,6,11) why does it not do this automatically if i use the default adaptive radio managed assigned?
    The reason I noticed this was because i was getting random disconnects from devices using the 2.4GHz band
  • 2.  RE: Adaptive radio management assigned on 2.4GHz
    MVP EXPERT
    Posted May 30, 2019 04:21 AM
    Is ARM enabled? With the defaults ARM will select either 1,6,11. However if the APs are not within earshot of each other and do not detect a sufficient amount of noise/interference then they may select the same channel if this is suitable.
  • 3.  RE: Adaptive radio management assigned on 2.4GHz
    Posted May 30, 2019 04:50 AM
    hi where can i tell if ARM is enabled?
    Thanks Craig
  • 4.  RE: Adaptive radio management assigned on 2.4GHz
    MVP EXPERT
    Posted May 30, 2019 05:15 AM
    Under RF -> ARM
  • 5.  RE: Adaptive radio management assigned on 2.4GHz
    Posted May 30, 2019 09:26 AM
    when u say is arm enabled, i presume it wont work without arm? what exact setting constitutes arm being enabled, i have attached my arm tab screenshot
