I have a working login for the Aruba Licensing site for one of my controllers. I need to add 2 more of our controllers to that site but I cant figure out how to do it. Has anyone been able to do this I do I need to contact Aruba directly?
You need to activate a new certificate ID; then on the subsequent page add the Serial Number of your new controller. You don't add the controller individually.
What you need to do is activate the certificate IDs (licenses) that will belong to those controllers and then it will ask you to add the serial # of the controller .
Once you do that the controllers will show up under the my controllers tap
Thank you guys. That worked out great.
