add IAP-205 to Static wired network as DHCP
  • 1.  add IAP-205 to Static wired network as DHCP
    Posted Nov 13, 2015 04:09 PM
    I Have a Wired Static IP Active directory Network where i want to install IAP-205 Units and Add them to then same subnet as the wired network But have the WiFi Portion set as DHCP..  I Have selected a Portion of the Subnet to set asside fore the DHCP Portion But I get a Overlapping error each Time I try this ..
    the Network has Servers, Printers and Workstations all between 10.0.1.2 and 10.0.1.30 with the Router (Gateway) at 10.0.1.1 I wanted to setup the Wifi Portion from 10.0.1.40 thru 10.0.1.70 ..  Ive setup numerous Locations in this fashion with No Issues using Linsys & Apple Airport Extreme units But the Aruba Unit is Fighting Me..
  • 2.  RE: add IAP-205 to Static wired network as DHCP
    Posted Nov 14, 2015 12:30 PM
    What device is showing you it has an overlap error?  A diagram would be helpful.
