Add IAP to Cloud Central
  • 1.  Add IAP to Cloud Central
    Posted Jun 19, 2015 10:58 AM
    I've created a trial account on Cloud Central to show the resources to a new customer. How I can add my own Instant AP to my Aruba Central?
    Paulo Raponi
  • 2.  RE: Add IAP to Cloud Central
  • 3.  RE: Add IAP to Cloud Central
    Posted Jun 19, 2015 01:05 PM
    This video are old. The Aruba Central has a new interface.
    The Device Management are a disabled menu. And even when I succed acceced it, the option to ADD DEVICE does not exist anymore.
  • 4.  RE: Add IAP to Cloud Central
    Posted Jun 19, 2015 01:08 PM
  • 5.  RE: Add IAP to Cloud Central
    Posted Jun 19, 2015 01:22 PM
    This menu are disabled.
  • 6.  RE: Add IAP to Cloud Central
    Posted Jun 19, 2015 01:26 PM
    Are you under a group or all groups?
  • 7.  RE: Add IAP to Cloud Central
    Posted Jun 19, 2015 01:28 PM
    I did a logout and login again and the menu back.... I think that are a GUI bug...
