hi,
I want to add a single SSID to a particular AP, is that possible under MM and MD setup ? the particular AP is part of a group and someone requested if it's possible to add a second SSID to that AP. the AP is part of an ap-group but I dont want to add that SSID for the whole group.
Is this possible ? Thanks
You would have to add the Virtual AP using the ap-specific configuration (commandline only on ArubaOS 8.x and above:
https://www.arubanetworks.com/techdocs/ArubaOS_86_Web_Help/Content/arubaos-solutions/1cli-commands/ap-name.htm?Highlight=ap-name
To be specific, you would do this:
config t
ap-name <name of ap that you want to add the wlan to>
wlan virtual-ap <Virtual AP you want to add>
write mem
