Cloud Managed Networks
Add Switch as Monitor Only
  • 1.  Add Switch as Monitor Only
    Posted Mar 08, 2019 06:58 PM
    Hello team,
    Unfortunately we were told that Central was able to do everything we needed, but we found that it was not able to. As a result, we're trying to add switches as monitored only devices since they're all configured. It doesn't appear to be working.
    Anyone have advice on this?
  • 2.  RE: Add Switch as Monitor Only
    MVP EXPERT
    Posted Mar 11, 2019 04:34 AM
    Are you able to clarify exactly what is not working? Only certain Switches and firmwares versions are supported by Central.
    http://help.central.arubanetworks.com/2.4.7/documentation/online_help/content/public_cloud/get_started/supported_switches.htm
    Are these switches already configured and you are trying to import them into Central?
  • 3.  RE: Add Switch as Monitor Only
    Posted Mar 16, 2019 10:11 AM
    Yes, as I said they are already configured and we’d like to add them to Central for monitoring only. Simply being able to add them as monitor is not an option, it seems.
    I have found I can add the configured switches to a Template group, but I’m concerned about overwrite.
  • 4.  RE: Add Switch as Monitor Only
    Posted Mar 16, 2019 10:24 AM
  • 5.  RE: Add Switch as Monitor Only
    Posted Mar 19, 2019 12:09 PM
    That doesn't really tell me any more than I know. Just to summarize, then:
    • There is no monitor only mode and we should have had Airwave.
    • Switches cannot be added without losing their configuration in a production environment.
    • 8400 still not supported.
  • 6.  RE: Add Switch as Monitor Only
    Posted Mar 25, 2019 01:45 PM
    For 1 and 2:  If your expectation is just to monitor switch with Central and do the configuration outside of central, this is not available as of today.
    For 3: No support for 8400 as of today.
