Add users to the Virtual controller database
  • 1.  Add users to the Virtual controller database
    Posted Feb 02, 2015 02:23 AM
    Is there a way to develop applications that configure the IAP without using the web browser or the CLI ? I want to create an app that creates guest users and generate random passwords and adds them to the cluster database and displays the existing ones, what do I need to do that ?
    Thanks.
  • 2.  RE: Add users to the Virtual controller database
    Posted Feb 02, 2015 07:43 AM
    Why don't you have an application that does everything you mentioned that on an external server and the IAP would query it via radius?
  • 3.  RE: Add users to the Virtual controller database
    Posted Feb 02, 2015 04:18 PM
    Thanks for the suggestion, I know there are applications that do that but I just want to have a simple add that adds and delete users from the virtual controller database without using the web UI.
  • 4.  RE: Add users to the Virtual controller database
