Addind ap to a standalnoe controller using arubaOS 8.4
This thread has been viewed 30 times
  • 1.  Addind ap to a standalnoe controller using arubaOS 8.4
    Posted Jun 17, 2019 10:00 AM
    Hi
    We upgrade our stand-alone controller to arubaos 8.4 and now we cannot add a new ap to our ap-group. the ap is provisioned with default group and we can't find where it can be changed.
    and generally the WebUI doesn't work well for such configuration (one stand alone controller). we cannot do anything with the access points - there are error about "invalid config path" and a lot of other options doesn't work at all, leading to js errors.
    We would appreciate any help
  • 2.  RE: Addind ap to a standalnoe controller using arubaOS 8.4
    MVP EXPERT
    Posted Jun 17, 2019 10:20 AM
    You'll find this under Mobility Controller -> Access Points. Select the AP you wish configure and choose Provision, the next screen will give you the option to change the ap-group.
    Are you able to provide a screenshot of the error? What browser and version are you using?
    If you are having issues with the GUI, you can always provision via the CLI
    (Aruba7030) *[mynode] #ap-regroup
    ap-name                 Regroup AP with this name
    serial-num              Regroup AP with this serial number
    wired-mac               Regroup AP at this MAC address
    (Aruba7030) *[mynode] #ap-regroup ap-name TEST-AP
    <new-group>             Name of AP's new group
  • 3.  RE: Addind ap to a standalnoe controller using arubaOS 8.4
    Posted Jun 17, 2019 01:57 PM
    Thank you very much!
    I used the cli (which I prefare, but I didn't find the commands).
    The WebUI is very bugy, at least in our case. We have no dashboard, when clicking on the controller, we cannot go back to the main configuration page unless we click on the icons of the active ap. many of the buttons do nothing, and while the "provision" button seems to do something, the page is refreshed instantly, before we can enter information, and we receive the attached message:Screenshot from 2019-06-17 20-18-24.png
    As you can see, there are no controllers shown in the "controllers" indication box, but we can see the controller under the menu
  • 4.  RE: Addind ap to a standalnoe controller using arubaOS 8.4
    Posted Jul 03, 2019 04:11 AM
    I am having the same issues with my web GUI.
    Were you able to get it working again?
  • 5.  RE: Addind ap to a standalnoe controller using arubaOS 8.4
    MVP EXPERT
    Posted Jul 03, 2019 04:43 AM
    What browser version and AOS version are you running?
  • 6.  RE: Addind ap to a standalnoe controller using arubaOS 8.4
    Posted Jul 03, 2019 04:51 AM
    Running on version 8.5.0.0 and i have tested Chrome, Edge and IE with same result on all.
  • 7.  RE: Addind ap to a standalnoe controller using arubaOS 8.4
    Posted Aug 08, 2019 03:39 AM
    hi,
    i facing the same issue. how to make GUI workable again on this ?
  • 8.  RE: Addind ap to a standalnoe controller using arubaOS 8.4
    Posted Aug 08, 2019 03:59 AM
    Hi
    It was a problem with the upgrade/migration proccess.
    HPE's support team worked on it for couple of days and there at least we had to re-configure the controller.
  • 9.  RE: Addind ap to a standalnoe controller using arubaOS 8.4
    Posted Dec 03, 2019 08:22 PM
    @tamar wrote:
    Hi
    Hi!
    I'm facing the same issue right now.
    Where you able to restore the configuration, or does this break the GUI again?
    Do we have to do a factory reset and type in every single line of config?
    Thank you!
  • 10.  RE: Addind ap to a standalnoe controller using arubaOS 8.4
    Posted Jan 28, 2021 04:41 AM
    I have the same problem.
    Did you restore the config or did you have to retype everything?
    thanks
    Tobias Gabriel
  • 11.  RE: Addind ap to a standalnoe controller using arubaOS 8.4
    Posted May 11, 2021 08:03 AM
    Hi!
    Sorry, I'm a little late, but better than never....
    I was able to figure out the couse of the broken GUI last week when I was upgrading a customers environment.
    Check out this topic: AOS 8.4.x GUI not fully functional after MCM migration from 6.5.x
    I restored the config to 6.5.0.16 and migrated a second time to 8.3.
    The migration to 8.4 will convert the controller to master mode, not to standalone and this will kill the GUI (looks like MM afterwards).
    If you use 8.3, it will work....
    Best regards, mom
