Thank you very much for the reply and suggestions. I already knew this going in, and was hoping to gather some metrics to back me up, but this is not a workable solution for me. What I really need is 2 dedicated 10G switches to increase throughput in my 3-node Windows failover cluster. I use 3 identical Dell PE R820 servers to host the Microsoft Hyper-V VM's. Each server (Node-1, Node-2, Node-3) has an Intel X520 DP 10Gb DA/SFP+, + I350 DP 1Gb Ethernet NDC and 1 x Intel I350 QP 1Gb NIC..
In order for failover to work properly, I need 2 switches to support 10G connections from each of the R820's. If I'm going to have 2 10G switches, I might as well put 10G cards in my other servers to take advantage of the network throughput.
I need two 12 or 24 port 10G switches to make this work. In order to reduce I'd like to use SFP+ fiber. Can anyone offer suggestions for refurbished/used 10G switches which would be a good fit for me?
Thanks again!
