Cloud Managed Networks
Adding 2530-POE+ 8G to central
  • 1.  Adding 2530-POE+ 8G to central
    Posted Nov 19, 2018 09:17 AM
    Hi!
    I'm trying to evaluate switch support in Aruba Central.
    But I get stuck on step1, adding the switch.
    Tried adding my lab switch J9774A with S/N and Mac with the info I get from these commands:
    sh system | in Serial
    sh system | in Base
    But central tells me "Either MAC Address or Serial number is incorrect".
    Any suggestions ?
    #2530
  • 2.  RE: Adding 2530-POE+ 8G to central
    Posted Nov 19, 2018 04:02 PM
    Hi, make sure you run firmware 16.3 or higher.
    Also, check if your dns can be resolved.
    If you still get the error, I think you have to contact TAC to check the backend database
  • 3.  RE: Adding 2530-POE+ 8G to central
    Posted Nov 23, 2018 03:32 AM
    Hi!
    I can ping google.com from the switch and I'm running 16.07
  • 4.  RE: Adding 2530-POE+ 8G to central
    Posted Nov 23, 2018 03:16 PM
    That sometimes happens with eval units that may not be in the right inventory. Please open a TAC case to get some help.
