Thank you for the assistance. I am working on configuring this controller remotely so I want to tread lightly here since the controller is located a few states away from me. So my understanding is, I need to create a new ap system profile and set the lms IP to the secondary controller, then create a new ap group pointin to the new ap system profile.
Here is the current config
------current config-----------------------------
ap system-profile "apsys_prof-zzo23"
ap-group "JJJ"
virtual-ap "JJJPublic-vap_prof"
virtual-ap "JJJNetwork-vap_prof"
virtual-ap "LanTest-vap_prof"
ap-system-profile "apsys_prof-zzo23"
dot11a-traffic-mgmt-profile "QOS"
dot11g-traffic-mgmt-profile "QOS"
ids-profile "ids-disabled"
-----end current config-------------------------
so is it correct to assume I need to add the following
ap system-profile "apsys_prof-secondary"
lms-ip 10.8.200.110
ap-group "JJJSecondary"
ap-system-profile "apsys_prof-secondary"
and then finally provision my selected aps in the new secondary ap group...
thanks
