Adding a local controller
  • 1.  Adding a local controller
    Posted Nov 11, 2013 11:00 AM
    My organization purchased two addition controllers to put in our chassis. My plan is to make them local controllers. My master is running 6.1.3.9 and I'm sure the others are a lower version of code but I haven't installed them yet.
    Should I bring up the new controllers as masters and upgrade them to the same code level then change them to locals or can I bring them up as locals and do the upgrade them then.
  • 2.  RE: Adding a local controller
    Posted Nov 11, 2013 11:23 AM
    both methods will work for u.
    my adivse..first be sure to have the same AOS on your new controllers...and then add them as locals.
    rgrds,
    Birenbaum Asa
  • 3.  RE: Adding a local controller
    Posted Nov 11, 2013 11:29 AM
    Thanks, I have the first one online and it is running 6.1.3.4. I'll plan on upgrading it before I put it on the network then add it as a local.
