Network Management
  • 1.  Adding a Wired Switch (not a AP) to a Floor Plan
    Posted Dec 12, 2019 07:03 AM
    Hi Everyone
    I am looking for a solution of how to show not only our AP's on floorplans, but also the location of our Aruba 2530 switches (8/24/48 port)
    The idea is that we can see on one plan the locations of these switches in the remote comm cabinets, alongside the AP data and heat maps.
    Its really for point of reference rather than needing any active data.
    Cheers
    Craig
  • 2.  RE: Adding a Wired Switch (not a AP) to a Floor Plan
    Posted Dec 12, 2019 01:04 PM
    This would be a useful feature. Also it would be nice to add items to network topology manually.
  • 3.  RE: Adding a Wired Switch (not a AP) to a Floor Plan
    Posted Dec 12, 2019 01:15 PM
    @triggers88 wrote:
    Hi Everyone
    Cheers
    Craig
    Are you referring to the "wiring closet" feature in Airwave?
  • 4.  RE: Adding a Wired Switch (not a AP) to a Floor Plan
    Posted Dec 18, 2019 01:57 PM
    Thanks cjoseph
    But I am not looking for a wiring closet layout.
    I'm looking to add Wired switches to a floorplan, in the same way you can add wireless access ports....
  • 5.  RE: Adding a Wired Switch (not a AP) to a Floor Plan
    Posted Dec 19, 2019 06:29 AM
    Currently we do not have this feature , please file one at
    innovate.arubanetworks.com/
  • 6.  RE: Adding a Wired Switch (not a AP) to a Floor Plan
    Posted Aug 31, 2022 02:47 PM
    Using 8.2.14 and I cannot find anything like this in the documentation or system for wiring closets. Was the closet mapping removed?
  • 7.  RE: Adding a Wired Switch (not a AP) to a Floor Plan
    Posted Sep 12, 2024 08:25 AM
    9/12/2024 - Is this a thing yet?
  • 8.  RE: Adding a Wired Switch (not a AP) to a Floor Plan
    Posted Sep 23, 2024 12:18 PM
    Its not in AirWave. But is part of Floor Plan Manager in Central.
    Regards
    Gowri Amujuri
