Adding a Wiring Closet on Airwave 8.0
  • 1.  Adding a Wiring Closet on Airwave 8.0
    Posted Jun 18, 2014 03:28 AM
    Good Day
    Just upgraded my Production Env to Airwave 8.0. Funny thing is I cannot seem to find where to add a Wiring Closet for my switches.
  • 2.  RE: Adding a Wiring Closet on Airwave 8.0
    Posted Jun 18, 2014 05:34 AM
    "Wiring Closet" is located under Drawing a Region.  Please search the online help in Airwave (under Documentation) to see how it is done.
  • 3.  RE: Adding a Wiring Closet on Airwave 8.0
    Posted Jun 18, 2014 07:40 AM
    Draw a region on the VisualRF en select the 'Wiring closet' region type for it.
    Double click on it to enter the closet view.
  • 4.  RE: Adding a Wiring Closet on Airwave 8.0
    Posted Jun 18, 2014 09:17 AM
    Hey guys,
    I just tried this myself and nowhere I see where you can choose a wiring closet, the documentation is not correct either.
    I have tried on an already existing floorplan and adding a new one.
    The options we have are below. Planning, Boundary and probability
  • 5.  RE: Adding a Wiring Closet on Airwave 8.0
    Posted Jun 18, 2014 12:09 PM
    Adding a closet is only available for the non-html5 (flash) version of VisualRF.  You can toggle this by going to VRF -> Setup -> toggle ‘enable html5’ to no, save/apply.  After a few minutes, you should have the Old (flash) version of the site that would allow adding Closets.  You can toggle it back by turning on Enable HTML5 to see the new (non-flash) version of the site.
    Sorry in advance for the confusion.
  • 6.  RE: Adding a Wiring Closet on Airwave 8.0
    Posted Jun 18, 2014 12:15 PM
    A quicker way to switch is using https://youramp/vrf to access the HTML5 (new) version of the site and:
    https://youramp/site_list to access the Flash (older) version of the site.
  • 7.  RE: Adding a Wiring Closet on Airwave 8.0
    Posted Jun 18, 2014 12:24 PM
    Thanks Colin. I assume this will be ported over to the HTML5 version at some point
  • 8.  RE: Adding a Wiring Closet on Airwave 8.0
    Posted Apr 19, 2016 01:39 PM
    Hey Colin,
    I was wondering if this was ever going to be added to the HTML5 VRF. I'm currently running 8.2.0.1, and being able to track wiring closets even logically on our VisualRF maps would help us a ton. Do you know if this is on the roadmap?
  • 9.  RE: Adding a Wiring Closet on Airwave 8.0
    Posted Jun 18, 2014 12:25 PM
    Let me try to find out...
  • 10.  RE: Adding a Wiring Closet on Airwave 8.0
    Posted Jun 26, 2014 09:24 PM
    Any luck?
  • 11.  RE: Adding a Wiring Closet on Airwave 8.0
    Posted Aug 11, 2014 05:23 PM
    I hope this is on the roadmap too.
