Adding an AP274 to existing network instant v 6.4.2.3-4.1.15-49609
  • 1.  Adding an AP274 to existing network instant v 6.4.2.3-4.1.15-49609
    Posted Nov 18, 2016 03:05 PM
    Specs call for
    Aruba Instant 4.1 (AP-274, AP-275),
    ArubaOS 6.4 (AP-274, AP-275), Aruba OS 6.4.3 (AP-277)
    Will this be plug and play or are there other things I need to consider, ie I can assign an ip address and the ap274 will find the controller?
  • 2.  RE: Adding an AP274 to existing network instant v 6.4.2.3-4.1.15-49609
    Posted Nov 18, 2016 03:14 PM
    Are you deploying on an existing Instant network or an existing AOS? What is the existing IAP hardware (what AP models)?
    SHOULD be fine, but more info would be helpful to nail it down.
    Will the AP just be serving clients outdoor, are you planning on mesh, etc?
  • 3.  RE: Adding an AP274 to existing network instant v 6.4.2.3-4.1.15-49609
    Posted Nov 18, 2016 03:38 PM
    Current Network has 11 AP105, each assigned a static ip, etc. Planning on assigning an IP address to the AP274 and connecting to a poe switch on the existing instant network.
  • 4.  RE: Adding an AP274 to existing network instant v 6.4.2.3-4.1.15-49609
    Posted Nov 18, 2016 03:39 PM
    So you will need to manually bring the 274 to the same image as the AP-105s (or upgrade the 105s to whatever the 274 is running, whichever you think is easier), and make sure that the 274 is on the same network/Layer2 as the other AP-105s.
  • 5.  RE: Adding an AP274 to existing network instant v 6.4.2.3-4.1.15-49609
    Posted Nov 18, 2016 03:54 PM
    Thank you for your quick responses, do you have info on how "to manually bring the 274 to the same image as the AP-105s"?
  • 6.  RE: Adding an AP274 to existing network instant v 6.4.2.3-4.1.15-49609
    Posted Nov 18, 2016 04:08 PM
    I am not an expert, others may have better advice.
    For me, the easiest way with a new AP is bring it up on it's own network segment (a different L2), connect to the Instant SSID and download the firmware I need it to run, install it, let it reboot, and then I can move it over to the existing vlan.
