We have an environment with existing guest login via captive portal set up on the controller. We have a Clearpass server running in development. We would like to add guest self-registration to the existing system. I suppose that would involve a link on the controller's captive portal to the self-registration page hosted on Clearpass. At the moment users created manually on Clearpass can log into the controller's captive portal via RADIUS, but that's as far as we've gotten. Should this be possible?
You either need to create a new captive portal profile pointing to the new registration page (under Authentication > L3 Authentication). Make sure the server group is ClearPass.
or you can change the existing URL in your existing captive portal.
Thanks for your response. I need the existing captive portal to keep functioning, independent from the clearpass self-registration page. Do you think this is possible?
