Adding clearpass servers to Orion Solarwinds
  • 1.  Adding clearpass servers to Orion Solarwinds
    Posted May 29, 2014 09:36 AM
    Hello All,
    We have about 6 clearpass servers globablly that play a vital role in our NAC solutions.
    We'd like to add them to solarwinds, a tool I am sure many are you familiar with.
    Recently, I have succesfully added the 6 servers to solarwinds, however Orion is only monitoring it's interfaces. There is no CPU/Disk space or any other info. All our servers are virtual appliances hosted on an ESXi host.
    Could this be the reason? I feel as if I may have to import an MIB of some sort. Is there some sort of SNMP feature set I must enable?
    All other virtual servers we have push out the info listed above.
    Thanks for all help in advanced :smileyvery-happy:
  • 2.  RE: Adding clearpass servers to Orion Solarwinds
    Posted May 29, 2014 09:45 AM
    CPPM supports the standard host MIB file, it should provide up/down, disk, CPU, memory, and some other alerts.   CPPM does not have its own MIB (yet).
  • 3.  RE: Adding clearpass servers to Orion Solarwinds
    Posted May 29, 2014 09:55 AM
    Do you feel you are missing alerts?
    You should get alerts for the following:
    1. Disk space (30% by default)
    2. CPU load thresholds
    3. CPPM processes stop
    4. Management or Data interface up/down
    You can change some thresholds to test:
    Administration --> Server Manager --> Server Configuration --> Click on your server --> Service Parameters tab --> System Monitor Service --> Set CPU and Free Disk space thresholds
  • 4.  RE: Adding clearpass servers to Orion Solarwinds
    Posted May 29, 2014 09:49 AM
    The Clearpass user guide has a description off all the OIDs and traps supported. Here are the ones you specifically called out:
    CPU Load Average Traps
    OIDs
    .1.3.6.1.4.1.2021.10.1.100.1 ==> Error flag on the CPU load-1 average. Value of 1 indicates the load-1 has crossed its threshold and 0 indicates otherwise.
    .1.3.6.1.4.1.2021.10.1.2.1 ==> Name of CPU load-1 average
    .1.3.6.1.4.1.2021.10.1.100.2 ==> Error flag on the CPU load-5 average. Value of 1 indicates the load-5 has crossed its threshold and 0 indicates otherwise.
    .1.3.6.1.4.1.2021.10.1.2.2 ==> Name of CPU load-5 average
    .1.3.6.1.4.1.2021.10.1.100.3 ==> Error flag on the CPU load-15 average. Value of 1 indicates the load-15 has crossed its threshold and 0 indicates otherwise.
    .1.3.6.1.4.1.2021.10.1.2.3 ==> Name of CPU load-15 average.
    .1.3.6.1.4.1.2021.9.1.100.1 ==> Error flag indicating the disk or partition is under the minimum required space configured for it. Value of 1 indicates the system has reached the threshold and 0 indicates otherwise.
    .1.3.6.1.4.1.2021.9.1.2.1 ==> Name of the partition which has met the above condition.
