Yes, Exit is required. I did have to bring your commands into Notepad and remove padding before the exits. Once removed it pasted without issue.
IAP-6x-205H-Standalone (config) #
IAP-6x-205H-Standalone (config) # wlan auth-server MYAUTHSERVER
IAP-6x-205H-Standalone (Auth Server "MYAUTHSERVER") # ip 10.25.9.20
IAP-6x-205H-Standalone (Auth Server "MYAUTHSERVER") # port 1812
IAP-6x-205H-Standalone (Auth Server "MYAUTHSERVER") # acctport 1813
IAP-6x-205H-Standalone (Auth Server "MYAUTHSERVER") # timeout 10
IAP-6x-205H-Standalone (Auth Server "MYAUTHSERVER") # key 41025146bfd523a420b45552619bf5
IAP-6x-205H-Standalone (Auth Server "MYAUTHSERVER") # rfc3576
IAP-6x-205H-Standalone (Auth Server "MYAUTHSERVER") # cppm-rfc3576-port 3799
MYAUTHSERVER") # exitIAP-6x-205H-Standalone (config) # wlan auth-server MYOTHERAUTHSERVER
IAP-6x-205H-Standalone (Auth Server "MYOTHERAUTHSERVER") # ip 10.25.1.20
IAP-6x-205H-Standalone (Auth Server "MYOTHERAUTHSERVER") # port 1812
IAP-6x-205H-Standalone (Auth Server "MYOTHERAUTHSERVER") # acctport 1813
"MYOTHERAUTHSERVER") # exitIAP-6x-205H-Standalone (config) #
Philip Wightman, ACEX (AMFX) #69. Aruba Partner Ambassador
Original Message:
Sent: Apr 27, 2022 11:30 AM
Subject: adding commands to a 515 cluster via CLI...do I need the "exit" commands between sections?
I have a number of commands that I need to insert into a number of 515 clusters, running 8.6.0.11.
The commands look like this:
ip 10.25.9.20
port 1812
acctport 1813
timeout 10
rfc3576
ip 10.25.1.20
port 1812
acctport 1813
etc...
If I want to apply this to a number of IAPs using CLI, I need to insert "exit" commands before the next wlan auth-server (or any other) section.
Is there a way to paste into CLI configure t mode that respects the indents for each section? If I import this config snippet via the GUI, then it will be OK. But the CLI needs the exits.
Ambi
Ambidexter
