Adding deleted APs to controller
  • 1.  Adding deleted APs to controller
    Posted Jan 09, 2014 03:55 PM
    We deleted several AP's from our switch/controller.  They have now been repurposed and when we plug them in they pull the correct IP for the controller but we do not see them appear in the Campus WL.  Is there a command we need to run to allow them to appear again?  We have rebooted controller and AP's several times with no luck.
  • 2.  RE: Adding deleted APs to controller
    Posted Jan 09, 2014 03:58 PM
    What do you see from the AP Console ?
    Can you ping the APs from the controller ?
    Have you made any changes on the controller ?
    On the controller run the following command :
    show log system all
  • 3.  RE: Adding deleted APs to controller
    Posted Jan 09, 2014 05:09 PM
    a few troubleshooting tips
    • Check if control-plane-security enabled...do auto-cert (Just to see if the AP'S starting to show up under ap installison window)
    • Connect console to one of the AP'S and see if they getting an IP + master IP/server in order to contact your controller. **Does thoese AP connected to the same VLAN / PORT / Switch they were connected before (With the same settings?)
    • Does thoese AP units got static IP ? (does it fitted to the VLAN they are in)
    • Maybe u added some more Ap'S in between - Did you have enough licensees ?
  • 4.  RE: Adding deleted APs to controller
    Posted Jan 10, 2014 09:01 AM
    1st I will explain what was changed.  We did run out of licenses.  I deleted the 2 AP's in our lab from the AP list and from the Security Plane AP White List.  So we could bring other AP's online.  We have since added more liceses, I have been able to bring new AP's out of the box online in the lab.  The two AP's I deleted continue to timeout after resolving the correct IP for the controller.
    • Check if control-plane-security enabled...do auto-cert (Just to see if the AP'S starting to show up under ap installison window).  >>>>Did Auto cert and also added one of the two AP's to WL manually no change for either AP.
    • Connect console to one of the AP'S and see if they getting an IP + master IP/server in order to contact your controller. **Does thoese AP connected to the same VLAN / PORT / Switch they were connected before (With the same settings?)>>> AP's pull IP via DHCP and correctly identify the correct IP of the controller before timing out.
    • Maybe u added some more Ap'S in between - Did you have enough licensees ?>>> Yes
  • 5.  RE: Adding deleted APs to controller
    Posted Jan 10, 2014 03:06 PM
    Can u connect a console cable to one of the problemtic AP'S and copy&paste all the output from the start of the boot process please.
    Did u maybe upgrade the AOS version of the controller?
    are these AP'S configured as RAP'S or as CAP'S? (and if they are configured as RAP - do u have enough address for vpn connectivity ?
  • 6.  RE: Adding deleted APs to controller
    Posted Jan 10, 2014 03:21 PM
    We did not upgrade the firmware.
    The AP's are configured as CAPs
    Here is AP boot up process from Console Cable-
    APBoot 1.2.4.4 (build 26618)
    Built: 2011-01-07 at 13:42:04
    Model: AP-10x
    CPU: AR7161 revision: A2
    Clock: 680 MHz, DDR clock: 340 MHz, Bus clock: 170 MHz
    DRAM: 128 MB
    POST1: passed
    Copy: done
    Flash: 16 MB
    PCI: scanning bus 0 ...
    dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
    00 00 168c 0029 00002 01 10000000 00000000 00000000 00000000
    01 00 168c 0029 00002 01 10010000 00000000 00000000 00000000
    Net: eth0
    Radio: ar922x#0, ar922x#1
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0xbf100000
    Invalid image format version: 0xffffffff
    Checking image @ 0xbf800000
    eth0 up: 1 Gb/s full duplex
    DHCP broadcast 1
    DHCP IP address: 10.130.99.243
    DHCP subnet mask: 255.255.255.0
    DHCP def gateway: 10.130.99.254
    DHCP DNS server: 192.168.19.147
    DHCP DNS domain: bebe.com
    ADP multicast 1
    ADP broadcast 1
    ADP multicast 2
    ADP broadcast 2
    ADP multicast 3
    Retry count exceeded
    DNS request 1 for aruba-master.bebe.com to 192.168.19.147
    T Using eth0 device
    TFTP from server 192.168.19.148; our IP address is 10.130.99.243; sending throug
    h gateway 10.130.99.254
    Filename 'mips32.ari'.
    Load address: 0x2000000
    Loading: #T T #T T #T T ##
  • 7.  RE: Adding deleted APs to controller
    Posted Jan 10, 2014 03:25 PM
    It's seems like your AP can't get the AOS as needed. (failed doing all the TFTP needed process)
    A.What is the IP of your aruba master?
    192.168.19.148 or 192.168.19.147?
    B.Can u stop the AP from boot (with fasdt click on enter key) and run:
    factory_reset
    (it will clearos/purgeenv and will set the ap to default settings)
  • 8.  RE: Adding deleted APs to controller
    Posted Jan 10, 2014 03:33 PM
    No change after factory defualting the AP.
    19.147 is DNS server
    19.148 is Controller
  • 9.  RE: Adding deleted APs to controller
    Posted Jan 10, 2014 03:36 PM
    Can u try to stop before boot (enter key)
    and write:
    setenv master 192.168.19.148
    setenv serverip 192.168.19.148
    saveenv
    boot
    copy&paste the output , please.
  • 10.  RE: Adding deleted APs to controller
    Posted Jan 11, 2014 06:33 AM
    Any update?
  • 11.  RE: Adding deleted APs to controller
    Posted Jan 15, 2014 04:19 PM
    After purgeenv on AP it showed up in Controller as down(denied).  I went to the Campus Whitelist and moved it to factory-cert with a state of certified-factory-cert. rebooted AP and no change.  New AP's I am able to bring into WL and set profile to without any problem.
  • 12.  RE: Adding deleted APs to controller
    Posted Jan 15, 2014 04:32 PM
    Can u configure auto-cert under control plane security? and try agian to bringup thoese denied units please.
  • 13.  RE: Adding deleted APs to controller
    Posted Jan 16, 2014 07:35 AM
    For those AP's under Flags what do you have. (when you do the show ap database long - even if they are down they will have some flags there).
  • 14.  RE: Adding deleted APs to controller
    Posted Jan 10, 2014 03:35 PM
    • is there any Firewall / NAC on on 10.130.99.254 ?
    • does the needed ports are open? TFTP ports?
  • 15.  RE: Adding deleted APs to controller
    Posted Jan 10, 2014 08:06 PM
    I had problems with some RAP's too that with a factory_reset wouldn't work. The only way we were able to get them back online was to do a purgeenv instead of the factory_reset.
