Network Management
Adding devices to Airwave
  • 1.  Adding devices to Airwave
    Posted Aug 08, 2014 01:17 PM
    Can someone tell me how to add devices to Airwave?
    I doesn't seem to want to find some of my Aruba controllers.
    I've added the proper subnet for scanning, but still no luck.
    Is there a way to manually add a single device?
    Tony
  • 2.  RE: Adding devices to Airwave
    Posted Aug 08, 2014 01:51 PM
  • 3.  RE: Adding devices to Airwave
    Posted Aug 08, 2014 02:58 PM
    How did I miss that???
    Thank you!
  • 4.  RE: Adding devices to Airwave
    Posted Aug 09, 2014 01:37 PM
    One way is to use SNMP. To do this your SNMP credentials much be matching between controller and Airwave.
  • 5.  RE: Adding devices to Airwave
    Posted Apr 13, 2016 11:15 AM
    Is there an API to add/remove devices from AirWave?
  • 6.  RE: Adding devices to Airwave
    Posted Apr 13, 2016 11:33 AM
    Type https://<ip address of airwave server>/api to see what is supported and how.
  • 7.  RE: Adding devices to Airwave
    Posted Apr 13, 2016 11:57 AM
    Thanks Colin,
    Where can I find details and examples using the API? I've looked through the Aruba Documentation files, but dont' see anything related to the API.
    Matt
  • 8.  RE: Adding devices to Airwave
    The API documentation is on the Airwave Server:
    https://<ip adddress of airwave>/api
