Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
Adding different model AP to running instant
  • 1.  Adding different model AP to running instant
    Posted 7 days ago
    Hi everyone.
    We have a running Aruba instant deployment consisting of 30x Aruba 303 access points. Is it possible to add few 505 or 515 model AP's to this instant?
    We are also planning on building another instant deployment on Aruba 505 devices, but we were thinking of using few 515 in crucial spots where density of clients might be higher. Is that usual thing to do, and can Instant Deployment be based on mix of 505 and 515 devices?
    Thank's for your help.
  • 2.  RE: Adding different model AP to running instant
    MVP GURU
    Posted 7 days ago
    Yes you can cluster multiple models together. They all need to be running the same version in order to achieve this. You will have to manually upgrade each new AP type to the same version as the current cluster. Once you have the new AP added, any AP connecting after that will download the code from the "seed ap" and upgrade itself to the same version after booting.
    You will need to create two "seed aps"
    510s use Draco (for example ArubaInstant_Draco_8.10.0.6_86193
    505s uses Gemini (for example ArubaInstant_Gemini_8.10.0.6_86193)
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
