Network Management
Adding HP 2920 (J9729A) to Airwave
  • 1.  Adding HP 2920 (J9729A) to Airwave
    Posted Nov 25, 2016 02:56 PM
    I'm having a heck of a time adding the above switch to airwave. It's running firmware WB.16.01.0006, ROM WB.15.05. Airwave is running 8.2.2.
    Here is a summary of what has been done so far and I should add that this has been completed with the help of Aruba TAC:
    • Ping the device successfully from Airwave.
    • Verified on the switch and found community string and SNMP V3 is configured.
    • Tried to added the device manually from Airwave however, its shows down in Airwave and configuration as unknown.
    • Deleted the device and tried adding the device by creating scan-set but it failed.
    • Deleted the group and created a new group and changed the group display setting as all devices.
    • Changed the SNMP V3 for HP devices.
    • Tried adding the device but it failed.
    • SNMP walk from Airwave to device is getting failed.
  • 2.  RE: Adding HP 2920 (J9729A) to Airwave
    Posted Nov 25, 2016 05:44 PM
    Had to disable "snmpv3 only" on the switch.
    Seems silly to me that we would have to do that though...
