Adding IAP-204 to IAP-104 network
  • 1.  Adding IAP-204 to IAP-104 network
    Posted Nov 04, 2015 01:05 PM
    Wanting to add to my IAP-104 cluster, I discovered that the IAP-104s are no longer available. So my vendor sent me IAP-204s. I unpacked the first device and connected it to my network, but my virtual controller can't see it. I talked to my vendor, who said I'd need to upgrade the firmware on my IAP-104s. But when I click on the "check for new version" botton, a message comes back saying there is no new version. But my version is 6.1.3.1-3.0.0.1_33617, and the vendor said I needed at least 4.1.1.0. Is updated firmware available for my devices? If so, how do I get it? If not, is there any way to get the IAP-204 devices talking to my IAP-104 cluster, or am I out of luck?
  • 2.  RE: Adding IAP-204 to IAP-104 network
    Posted Nov 04, 2015 01:07 PM
    What version is your cluster running on right now?
  • 3.  RE: Adding IAP-204 to IAP-104 network
    Posted Nov 04, 2015 01:48 PM
  • 4.  RE: Adding IAP-204 to IAP-104 network
    Posted Nov 04, 2015 01:51 PM
    Any change of upgrading that cluster?  the 204 does not have code that far back and will not join the cluster if it does not match code.
  • 5.  RE: Adding IAP-204 to IAP-104 network
    Posted Nov 04, 2015 02:08 PM
    That's frustrating, as I bought the last of the 104s only about a year ago and they were still being sold retail at that time.
  • 6.  RE: Adding IAP-204 to IAP-104 network
    Posted Nov 04, 2015 02:10 PM
    Are you saying that upgrading code to support new hardware is frustrating?  The AP simply didn't exist when your older code came out, so there is no build for it...
  • 7.  RE: Adding IAP-204 to IAP-104 network
    Posted Nov 04, 2015 02:12 PM
    No, I'm saying that I was sold devices and assured that they'd work with my current network, when that isn't the case. And that's what's frustrating. Also that my devices aren't that old - only a year - and they're already obsolete.
  • 8.  RE: Adding IAP-204 to IAP-104 network
    Posted Nov 04, 2015 02:14 PM
    They will work with your current network if you upgrade the code to support the newer devices.  Your devices are not obsolete--they are still supported, but not being sold anymore.  There is a difference.
  • 9.  RE: Adding IAP-204 to IAP-104 network
    Posted Nov 05, 2015 04:04 PM
    Which comes back to my original question about where to locate the software to upgrade the IAP-104s.
  • 10.  RE: Adding IAP-204 to IAP-104 network
