APBoot 1.5.3.12 (build 45191)
Built: 2014-08-04 at 11:37:23
Model: AP-20x
CPU: BCM53011/15, revision A0
I2C: ready
SKU: 2
OTP: 0xeca01028
Clock:
CPU: 800 MHz
DDR: 533 MHz
AXI: 400 MHz
APB: 200 MHz
PER: 400 MHz
DRAM: 128 MB
POST1: memory passed
SF: Detected MX25L25635E with page size 4 kB, total 32 MB
Flash: 32 MB
PCIe0: RC, link up
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 14e4 4360 00002 03 08000004 00000000 00000000 00000000
PCIe1: RC, link up
00 00 14e4 4360 00002 03 40000004 00000000 00000000 00000000
Power: POE
Net: eth0
Radio: bcm43460#0, bcm43460#1
Hit <Enter> to stop autoboot: 0
Checking image @ 0x1e100000
Copying image from 0x1e100000
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
Uncompressing... done
[ 0.000000]
[ 0.000000] Aruba Networks
[ 0.000000] ArubaOS Version 6.4.2.0-4.1.1.0 (build 45444 / label #45444)
[ 0.000000] Built by p4build@cartman on 2014-08-15 at 21:51:21 PDT (gcc version 4.7.2)
[ 0.000000]
[ 0.000000] Flash variant: variant0
[ 0.000000] Memory: 128MB = 128MB total
[ 0.000000] Memory: 117892k/117892k available, 13180k reserved, 0K highmem
[ 0.052000] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[ 5.142000] PMU: registered new PMU device of type 0
[ 5.648000] pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
[ 5.650000] pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
[ 5.652000] pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
[ 6.154000] pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
[ 6.156000] pci 0002:02:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
[ 6.158000] pci 0002:02:00.0: BAR 0: set to [mem 0x40000000-0x40007fff 64bit] (PCI address [0x40000000-0x40007fff]
[ 6.504000] i2c-springbank: using remapped base c8904060
[ 6.506000] mpcore_wdt mpcore_wdt: enabling watchdog.
[ 6.510000] qspi_iproc qspi_iproc.1: 1-lane output, 3-byte address
[ 6.512000] m25p80 spi1.0: mx25l25635e (32768 Kbytes)
[ 6.514000] Creating 1 MTD partitions on "spi1.0":
[ 6.516000] 0x000000000000-0x000002000000 : "qspi"
[ 6.520000]
[ 6.520000] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
[ 6.524000] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
[ 6.538000] Starting Kernel DES KAT ...Completed Kernel DES KAT
[ 6.542000] Starting Kernel AES KAT ...Completed Kernel AES KAT
[ 6.544000]
Domain Name: instant.arubanetworks.com
No panic info available
Check backup ENV.
Cfg len is 0
Configuration file is empty, turning on default services...
extended ssid activate due to no AP config ...
[ 12.008000] ADDRCONF(NETDEV_UP): bond0: link is not ready
[ 14.010000] bond0: link up (1000FD)
[ 14.012000] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
Mesh is DISABLED on this device.
Disabling wpa_supplicant for this paltform
[ 15.074000] AP xml model 81, num_radios 2 (jiffies 7537)
[ 15.076000] init_asap_mod: installation:0
[ 15.078000] radio 0: band 1 ant 0 max_ssid 16
[ 15.080000] radio 1: band 0 ant 0 max_ssid 16
[ 15.082000] election init: rand=10 HZ=500
[ 15.084000] IAP client match init
notify asap_mod 3g no present...
Starting watchdog process...
Getting an IP address...
Dec 31 16:00:17 udhcpc[1354]: udhcpc (v0.9.9-pre) started
Dec 31 16:00:17 udhcpc[1354]: send_discover: pkt num 0, secs 0
Dec 31 16:00:17 udhcpc[1354]: Sending discover...
Dec 31 16:00:17 udhcpc[1354]: send_selecting: pkt num 0, secs 0
Dec 31 16:00:17 udhcpc[1354]: Sending select for 172.25.3.90...
Dec 31 16:00:17 udhcpc[1354]: Lease of 172.25.3.90 obtained, lease time 86400
Dec 31 16:00:17 udhcpc[1354]: DHCP OPT 43 deleted airwave config
172.25.3.90 255.255.255.0 172.25.3.1
Compressing all files in the /etc/httpd directory...
[ 20.096000] ip_time_handler: Got ip and packets on bond0 Started master election 14-0, rand 15
[ 20.936000] Adding bridge entry for magic vlan GW, ifindex 8450, 24:de:c6:cd:b5:f1
[ 20.938000] (00:00:22) !!! Init ---> Slave
Starting Webserver
bind: Transport endpoint is not connected
Launching NTP Client on pool.ntp.org
[ 21.784000] wifi0: AP type AP-205, radio 0, max_bssids 16
[ 21.828000] wifi1: AP type AP-205, radio 1, max_bssids 16
shutting down watchdog process (nanny will restart it)...
Completed SW FIPS KAT test
<<<<< Welcome to the Access Point >>>>>
User: [ 52.054000] asap_send_elected_master: sent successfully
[ 52.070000] process `snmpd_sap' is using obsolete setsockopt SO_BSDCOMPAT
[ 52.536000] wait for stm to initialize over
[ 52.538000] asap_send_elected_master: sent successfully
[ 57.076000] turn off mobility
[ 57.392000] (00:00:59) !!! Init ---> Slave
connected
System uptime is 126 seconds and CLI is not ready yet, please try again later.
Our cluster was being managed by an airwave server previously, but we have since powered down the server, would something like that be interfering with the iap joining the cluster?
#AP205
