adding IAP 535 to existing IAP 225 cluster
  • 1.  adding IAP 535 to existing IAP 225 cluster
    Posted Jan 03, 2021 10:57 PM
    I'm having some issues when I try to add IAP 535 into a existing AIP-225 cluster all with FW 8.6.0.4.
    The IAP 535 connects into the network and after adoption wired and wireless network starts having timeouts.
    Any one knows if there is any limitation clustering this 2 AP models?
    thanks
    Luis Lopes
  • 2.  RE: adding IAP 535 to existing IAP 225 cluster
    Posted Jan 03, 2021 11:02 PM
    are you connecting the E1 of the AP-535? if so just connect E0
  • 3.  RE: adding IAP 535 to existing IAP 225 cluster
    Posted Jan 04, 2021 05:24 AM
    no, I'm just conecting one port of the AP.
    Luis Lopes
  • 4.  RE: adding IAP 535 to existing IAP 225 cluster
    MVP EXPERT
    Posted Jan 04, 2021 06:01 AM
    What are the timeouts that you are seeing, are these timeouts seen by the client or via the network services on the IAP? Can you confirm the IAP-535  did indeed join the cluster successfully?
    Craig Syme
  • 5.  RE: adding IAP 535 to existing IAP 225 cluster
    Posted Jan 04, 2021 06:42 AM
    after IAP joins the cluster, network starts to timeout even in cabled ports
    Luis Lopes
