Adding IAP to Airwave
  • 1.  Adding IAP to Airwave
    Posted Jan 13, 2014 09:47 AM
    Our current process to add IAP's to our Airwave server is by adding just a 4 character site code to the Organization string.  This creates the equivalent folder and group in Airwave.
    As we have a lot of sites, this flat folder hierarchy is starting to become a bit unmanageable.
    What I'd like to be able to do is the following.
    Assume site code is WXYZ.
    When I add a new IAP top Airwave, I would liek the following to happen:
    Create a configuration group called "WXYZ"
    Create a new subfolder  under folder "Europe" called "WXYZ"
    Is it possible to do this using the Organization string syntaxes and if so, how.
    thanks
  • 2.  RE: Adding IAP to Airwave
    Posted Jan 13, 2014 11:10 AM
    You can do this with the Org String / opt 43.  By separating strings with a colon you are telling AirWave that it is a sub-folder.
    Example:
    top folder:sub-folder,Awave IP, secret
    Be sure there are no spaces.  You can have the same config across all folders or different configs for each folder.
  • 3.  RE: Adding IAP to Airwave
    Posted Jan 14, 2014 06:03 AM
    Hi Marcus,
    I tried this using the Instant Gui, but the problem is is that if I use the following Org string for example:
    EMEA:WXYZ
    A folder called WXYZ gets created as a subfolder of EMEA, which is what I want.
    But,  a Group also gets created called EMEA.   Which is not what I want, I need a group created called WXYZ as we use a template per site for deploying our IAP's.
    Is there anyway to make this work ?
  • 4.  RE: Adding IAP to Airwave
    Posted Jan 14, 2014 01:27 PM
    At the moment, that's how it's designed.  It'd be a feature request to change the existing behavior for groups.
