Adding IAP to Cluster
  • 1.  Adding IAP to Cluster
    Posted Oct 21, 2017 04:14 PM
    We have an IAP cluster of 8 IAPs (1-335, 3-325, 2-215, 2-205) using a virtual controller. Attemping to add 2-305s but they will not auto join. They are currently running 6.5.4.3_61877 firmware. We looked for this firmware for the 305s to upgrade them and can only find 6.5.4.2_61807. How do I get these new 305s to join?
  • 2.  RE: Adding IAP to Cluster
    Posted Oct 22, 2017 06:46 PM
    Before joining the 305s to the existing cluster , make sure the 305s are running the same level of code as the current cluster
    Get Outlook for iOS
