Adding IAPs to Aruba Central VisualRF
  • 1.  Adding IAPs to Aruba Central VisualRF
    Posted Oct 01, 2018 04:33 PM
    Hi all,
    i have problems adding IAPs to Aruba Central VisualRF. The "Add deployed devices" list is empty when i am trying to add APs to a floor plan. The IAPs are shown in Central correctly with all informations. Device subscription keys and one service subscription key for clarity are active and tied to the devices. Anything i am missing here? IAPs running on Firmware 8.3.0.3.
    Thanks for some input
  • 2.  RE: Adding IAPs to Aruba Central VisualRF
    Posted Oct 26, 2018 08:32 AM
    24h later - the problem was solved and the IAPs were available in Visual RF
  • 3.  RE: Adding IAPs to Aruba Central VisualRF
    Posted May 06, 2019 03:12 AM
    Dear,
    Same problem here - Did you had to do anything to make this work ?
  • 4.  RE: Adding IAPs to Aruba Central VisualRF
    Posted May 06, 2019 07:18 AM
    No, just wait and relax - will be fixed by magic :)
