Adding MDs and groups to the MM via CLI
  • 1.  Adding MDs and groups to the MM via CLI
    Posted Feb 06, 2018 10:11 AM
    Anyone know how to quickly add  via CLI an MD or group in the Managed Network hierarchy of the MM?
  • 2.  RE: Adding MDs and groups to the MM via CLI
    Posted Feb 06, 2018 11:01 AM
    I think I found it. But not sure of the right syntax. I believe I need to be under /md
    http://www.arubanetworks.com/techdocs/ArubaOS_81_Web_Help/Content/ArubaFrameStyles/Configuration_Hierarchy/Config_Hierarchy.htm
    Allowed Node Operations
    The following node operations are allowed on Mobility Master:
    Create Node: Creates a new node as the child of an existing node in the configuration hierarchy (system-generated or user-created)
    Add Device: Associates a device to an existing node in the hierarchy. This device inherits configurations from all nodes between the root node and the device (node-path).
    Delete Node: Deletes an existing user-created node or node without any child nodes. System-generated nodes cannot be deleted. Only leaf nodes without any child nodes can be deleted.
    Delete Device: Deletes a currently associated device from the configuration hierarchy. This will cause the device to reload and erase all configurations received from Mobility Master.
    Clone Node: Copies the configuration of an existing node into a new node. The new node is created as a child of an existing node in the hierarchy.
  • 3.  RE: Adding MDs and groups to the MM via CLI
    Posted Feb 06, 2018 02:42 PM
    Is this what you are looking for?
    Adding Group:
    (mm03) [mynode] (config) #configuration node /md/TEST
    (mm03) [mynode] (config) #cd /md
    /md
    /md/GUEST_T
    /md/PROD_DR_T
    /md/PRODUCTION_T
    /md/TEST
    <node-path>             Path of config node
    Adding MD:
    (mm03) [mynode] (config) #configuration device MAC-OF-YOUR-MD device-model MODEL /md/YOUR_GROUP
  • 4.  RE: Adding MDs and groups to the MM via CLI
    Posted Feb 06, 2018 05:09 PM
    Sure is :-) Thank you
