Adding meta data to Operator Profiles in GuestManager
  • 1.  Adding meta data to Operator Profiles in GuestManager
    Posted Apr 03, 2017 04:43 PM
    Wanted to ask if there was any way to add custom attributes to the operator profiles in GuestManager side.
    Similar to how we can add custom attributes to the devices when using the API. We want to be able to call the /api/operatorprofile and get a specific value from the profile that is not currently being passed through.
    Monil
  • 2.  RE: Adding meta data to Operator Profiles in GuestManager
    Posted Apr 03, 2017 04:46 PM
    Can you explain the exact use case?
  • 3.  RE: Adding meta data to Operator Profiles in GuestManager
    Posted Apr 11, 2017 11:03 AM
    sorry for the delayed response. We are using the api to add  the concept of personal vs departmental devies. The API will be adding on behalf of all users, and we are using the operator profile to distinguish between a personal device and a departmental device.
    We are hitting an issue when it comes to the max number of devices a user can add. A personal user may only add 5 devices while this device_limit number can change based on different departments.
    Each department (each associated operator profile) may in the future be able to increase their max device limitation. we were hoping to be able to add a "device_limit" field to the operator profile in order to easily grab that associated departments device limit.
    Monil
