Adding new 7220 controller to the network but do not want exisiting AP's to connect to it
  • 1.  Adding new 7220 controller to the network but do not want exisiting AP's to connect to it
    Posted Mar 02, 2016 08:20 PM
    Hello, as the title says we are going to be adding a new controller to our existing wireless environment but do not want the existing AP's we have in the environment to be picked up by the controller and automatically provisioned to the default profile.  Is there a recommended method to just add the controller onto the wire and have it sit there minding it's business so to speak, without interferering with the existing AP's?
  • 2.  RE: Adding new 7220 controller to the network but do not want exisiting AP's to connect to it
    Posted Mar 02, 2016 08:29 PM
    disable ADP discovery
    from CLI
    adp discovery disable
    And if you DNS don't change the Aruba-master to the new controller
    If you use DHCP option 43 don't add this controller
    Then you should be good.
    Sent from Outlook for iPhone
