Adding new AP 135 does not generate any heat in VisualRF
  • 1.  Adding new AP 135 does not generate any heat in VisualRF
    Posted Mar 26, 2013 09:38 PM
    I recently added a new AP to a new Floor in VisualRF.  When adding this AP I get no data from the AP about anykind of heatmap.
    It is just the AP and bunch of white space.  I've noticed that I do not get the same options when clicking on the AP as i do from APs in my network.  I've attached some screen shots of the AP in question.
    Thanks in advance.
  • 2.  RE: Adding new AP 135 does not generate any heat in VisualRF
    Posted Mar 26, 2013 09:57 PM
    That looks like a Dell (PowerConnect W AP135.  What version of airwave is this?
  • 3.  RE: Adding new AP 135 does not generate any heat in VisualRF
    Posted Mar 26, 2013 10:02 PM
    It is a dell power connect ap 135 and we are running dell branded airwave version 7.5.7
  • 4.  RE: Adding new AP 135 does not generate any heat in VisualRF
    Posted Mar 26, 2013 10:04 PM
    Okay.  I would click on System > VisualRF Engine (the logs) to see if there are any errors with that model AP.
  • 5.  RE: Adding new AP 135 does not generate any heat in VisualRF
    Posted Mar 26, 2013 10:14 PM
    I keep seeing this over and over again in that log file:
    2013-03-26 20:00:28,908 ERROR Placemnt Sch com.airwave.rf.PlacementSchedulerImpl AccessPoint not found with ID[111]
    2013-03-26 20:00:28,910 ERROR Placemnt Sch com.airwave.rf.PlacementSchedulerImpl AccessPoint not found with ID[110]
    2013-03-26 20:00:39,252 ERROR Placemnt Sch com.airwave.rf.PlacementSchedulerImpl AccessPoint not found with ID[121]
    2013-03-26 20:00:39,252 ERROR Placemnt Sch com.airwave.rf.PlacementSchedulerImpl AccessPoint not found with ID[111]
    2013-03-26 20:00:39,253 ERROR Placemnt Sch com.airwave.rf.PlacementSchedulerImpl AccessPoint not found with ID[110]
    2013-03-26 20:00:49,602 ERROR Placemnt Sch com.airwave.rf.PlacementSchedulerImpl AccessPoint not found with ID[121]
    2013-03-26 20:00:49,602 ERROR Placemnt Sch com.airwave.rf.PlacementSchedulerImpl AccessPoint not found with ID[111]
    2013-03-26 20:00:49,604 ERROR Placemnt Sch com.airwave.rf.PlacementSchedulerImpl AccessPoint not found with ID[110]
  • 6.  RE: Adding new AP 135 does not generate any heat in VisualRF
    Posted Mar 27, 2013 01:12 AM
    Are those the only error messages in the log?  Those messages wouldn't impact heatmaps.  Suggest opening a support case and sending them a full copy of the visualrf.log file.
