Adding second and third AIP-105
  • 1.  Adding second and third AIP-105
    Posted Jan 21, 2013 03:58 PM
    We had two AIP-105s setup together sharing a SSID.  One of them died and we have recieved the replacement.  I tried giving it an IP address on the same subnet, and then getting in to the web console to finish the config.  However, now when I hit that address it just redirects to the working AIP.  I see syslog errors about a image mismatch while trying to sync.
    What is the proper way to add another AP into the mix?  We actually will be adding a third one once we have the failed one back in place.
    Thanks.
  • 2.  RE: Adding second and third AIP-105
    Posted Jan 21, 2013 04:44 PM
    Just put it on the same subnet with dhcp and you are done!
