Adding secondary AD to Auth Source but can not make it trusted without certificate
  • 1.  Adding secondary AD to Auth Source but can not make it trusted without certificate
    Posted Aug 05, 2022 04:33 AM
    We have two different forest and two different Domains. We want to add secondary AD to the Auth source of a new service. The Clearpass joined both AD's but we couldn't add the second certificate without overriding the first one. And without certificate clients are not trusted. I am wondering how to make clearpass trust the second AD without adding the certificate? Thanks.
  • 2.  RE: Adding secondary AD to Auth Source but can not make it trusted without certificate
    Posted Aug 05, 2022 08:00 AM
    Are you using EAP-PEAP or EAP-TLS?
    If EAP-TLS are you looking "authenticate" certificates from both domains and then "authorize" with the username on the certificate after that?
    What is your workflow?
  • 3.  RE: Adding secondary AD to Auth Source but can not make it trusted without certificate
    Posted Aug 08, 2022 02:19 AM
    you can also create 2 similar services with matching rule on the username that contains the domain name and use 2 services certificates
    Regards
    Christian
