Comware
  • 1.  Adding SFPs to existing Flex 10 switch, hot pluggable?
    Posted Apr 16, 2013 11:51 AM
    Cannot find any info on adding additional SFPs to Flex 10 anywhere. No PDFs, no answers in the forums, and no help from HP India as "we don't understand what you are trying to say", well, the feeling is mutual (very thick accent).
    Can I hot plug an SFP+ into the Flex 10 switch, or do I have to pull the switch (which IS hot swappable), plug in the new SFP, and then re-install the Flex 10 switch.
    If anyone can direct me to documentation on a flex 10 expansion of SFPs it would be greatly appreciated, I cannot locate anything on HPs site search.
    #OnboardAdministrator
    #HotPluggable
    #c7000
    #Flex10
    #SFP
  • 2.  RE: Adding SFPs to existing Flex 10 switch, hot pluggable?
    Posted Apr 16, 2013 02:26 PM
    Wow, 30 views and no one yet? Please assist if possible, this is a time sensative issue.
    Thanks.
  • 3.  RE: Adding SFPs to existing Flex 10 switch, hot pluggable?
    Posted Apr 16, 2013 04:36 PM
    AFAIK, all switches of the current generation (and at least last 5 years) support hot plug of SFPs (ignoring some bug here), so that would include the flex 10 modules.
    There are several Flex10 modules available, so please be more specific in the question (e.g. with the part number),
    Best regards,Peter
  • 4.  RE: Adding SFPs to existing Flex 10 switch, hot pluggable?
    Posted Apr 16, 2013 04:55 PM
    HP BLC VC 1GB RJ45 SFP Part number 453154-B21 going into HP VC Flex-10 Enet Module Part number 455880-B21
    Same as the other 4 SFPs in the switch, they were in there from day 1 though.
    Thanks for the reply.
  • 5.  RE: Adding SFPs to existing Flex 10 switch, hot pluggable?
    Posted Apr 22, 2013 10:05 PM
    That should be no problem, just plugin and use them !
