Adding the remote AP will push the AP limits over the platform limit
This thread has been viewed 16 times
  • 1.  Adding the remote AP will push the AP limits over the platform limit
    Posted Jul 09, 2012 03:59 PM
    When I try to connect the controller via RAP2 from remote location, I see the below message.
    Adding the remote AP 00:24:6c:cd:4f:89 will push the AP limits over the platform limit..
    I also checked my licences RF protected licences seems. You can the licence summary below.
    (Controller) #show ap license-usage
    Total AP Licenses                       : 4
    Remote-Node AP Licenses Used            : 0
    AP Licenses Used                        : 4
    Tunneled Node Licenses Used             : 0
    Unused AP Licenses                      : 0
    Licenses used for Campus AP's           : 4
    Available Campus AP's                   : 0
    Licenses used for Remote AP's           : 0
    Available Remote AP's                   : 0
    Total Ortronics AP Licenses             : 0
    Ortronics AP Licenses Used              : 0
    Total Indoor Mesh AP's Supported        : 32
    Indoor Mesh AP's Active                 : 0
    Total Outdoor Mesh AP's supported       : 32
    Outdoor Mesh AP's Active                : 0
    Total RF Protect Licenses               : 8
    Remote-Node RF Protect Licenses Used    : 0
    RF Protect Licenses Used                : 4
    Total PEF Licenses                      : 4
    Remote-Node PEF Licenses Used           : 0
    PEF Licenses Used                       : 4
    Total 802.11n-OAW-AP120abg Licenses     : 0
    802.11n-OAW-AP120abg Licenses Used      : 0
    Total 802.11n-OAW-AP121abg Licenses     : 0
    802.11n-OAW-AP121abg Licenses Used      : 0
    Total 802.11n-OAW-AP124abg Licenses     : 0
    802.11n-OAW-AP124abg Licenses Used      : 0
    Total 802.11n-OAW-AP125abg Licenses     : 0
    802.11n-OAW-AP125abg Licenses Used      : 0
    Could you give me any advice about that?
    Thanks in advance.
  • 2.  RE: Adding the remote AP will push the AP limits over the platform limit
    Posted Jul 09, 2012 04:12 PM
    From your output, it looks like you have 4 AP licenses installed and are currently using them all.  You will have to add licenses for your RAPs.
    What version of code is this?
  • 3.  RE: Adding the remote AP will push the AP limits over the platform limit
    Posted Jul 09, 2012 04:36 PM
    olino,
    Thanks for your answer. When i shutdown an ap port, rap2 connected directly. So problem was solved.
  • 4.  RE: Adding the remote AP will push the AP limits over the platform limit
    Posted Jul 10, 2012 12:48 AM
    A quick footnote to this one...
    Just make sure if you want to add the '5th' RAP that you purchase  AP + PEFNG + RFP license for it (e.g. 3 part numbers/SKUs).
    If you just purchase an AP license you will still be unhappy at the result ... that being that the 5th RAP won't connect (same state you have now).
