Adding VC to central without existing config being overwritten
  • 1.  Adding VC to central without existing config being overwritten
    Posted Mar 07, 2015 07:22 PM
    I have a VC I had to remove from central to troubleshoot a captive portal issue.  Changes were made to correct the issue and now I would like to manage this VC with central again.  How can I acomplish this without the changes being overwritten?
  • 2.  RE: Adding VC to central without existing config being overwritten
    Posted May 18, 2015 08:35 PM
    1. Log into Central -> Maintance -> Unassign group for that VC or Select ALL GROUP agains that VC.
    2. Add VC back to Central. It will come as unprovisioned.
    3. Now click on unprovisioned VC and it will give you option to 1) add to existing group by overwriting existing config or 2) improt config to new group.
    4. Select 2nd option and you are all set.
