Adding WLAN Guest Voucher Printer to IAP network
  • 1.  Adding WLAN Guest Voucher Printer to IAP network
    Posted Nov 15, 2013 09:31 AM
    in a controller based solution, there is a possibility to generate vouchers for guest access which can be printed out with e.g. Zyxel SP-300E.
    Are the same functionalities implemented in an IAP solution as well or are there any differences?
    Thnaks and kind regards
    Kevin
  • 2.  RE: Adding WLAN Guest Voucher Printer to IAP network
    Posted Nov 15, 2013 05:41 PM
    That funcaiontlity isn't available today.  In our next reelase, we will have a guest registration login for the VC however, I am not sure what print capabilities will be there
