addition failed as max limit has been reached - but why?
This thread has been viewed 38 times
  • 1.  addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 05:47 AM
    Hello ladies and gentlemen,
    we have an MM-VA-500 - working fine. I have 6 controllers added to it but I can't add another one. I think I somewhen read about CPU limitation of the virtual mobility master but I can't find the document now.
    Can you please send me the document or tell me why there is the limition because it should be working with 50 controllers.
    Raffa
  • 2.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 06:20 AM
    Do you have the screenshot of the error?
  • 3.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 06:37 AM
    sure - here you go :) it is just "mac" + subject-text
  • 4.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 07:04 AM
    Do you have the output of "show log error 10" and "show log system 10"?  Also, what version of ArubaOS is this?
  • 5.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 07:19 AM
    it says: Jan 7 12:43:21 <profmgr 399816>  <5477> <ERRS> |profmgr|  Device remove failed.                          GSM update failed due to error 42 [error_no_free_slots
    Jan 7 12:43:21 <profmgr 399816>  <5477> <ERRS> |profmgr|  Error adding device 00                         :0b:86:b8:37:3d Error = error_no_free_slots
    which slots are not free?
    thanks
    raffael
  • 6.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 07:23 AM
    What is the output of "show inventory"?
  • 7.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 08:17 AM
    thanks for the help - looks like I got tricked.
    output: Active device type              : MM-VA-50
    but in the webinterface it says: licensepool 0/500 - so I can address 500 APs but with the VA-50 only 50 should be possible? Because devices are APs and controllers and clients are phones and so on, right? I already had up to 90 APs running at the same time with 2 controllers.
    and I have already 6 Controllers in the mobility master - so I am confused...
    regards,
    raffa
  • 8.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 08:22 AM
    You need to size your VM hardware with the correct specifications (memory, CPU, storage) otherwise it will see it as a 50. Shut down the VM, change the parameters and start it up again
  • 9.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 08:32 AM
    yes! at least I was not wrong - in my previous post I wrote " I think I somewhen read about CPU limitation of the virtual mobility master but I can't find the document now." - so i really tried to google and find the right document about specifications but could not find it. Do you mind helping me out here?
    thanks for the help!
  • 10.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 08:46 AM
    Please see the Virtual Machine Installation guide here:. https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=32542
    It will save you alot of frustrations
  • 11.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 07, 2019 08:55 AM
    yes, found it! thank you very much
  • 12.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 10, 2019 05:15 AM
    Hello again,
    can there occur some problems with the virtual maschine? Just shutdown, change specs and restart? Because it is a linux-system it could be critical no?
    Thanks in advance,
    raffael
  • 13.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 10, 2019 06:05 AM
    That is all that you need to do.  There should not be a problem with changing the specifications as long as your hardware supports it.
  • 14.  RE: addition failed as max limit has been reached - but why?
    Posted Jan 10, 2019 06:17 AM
    To be clear, shut down the VM, change the memory and processor to what is in the document.  When you restart the VM, look at the console messages while it is booting up to monitor the status of the VM.
