Adequate replacement for 7205 Controller?
  • 1.  Adequate replacement for 7205 Controller?
    Posted 22 days ago
    Last friday a mail arrived that i was honestly expecting for quite a while.
    The 7205 Controller goes end of sale in November...
    The mail lists the 9114 Controller as a replacement, but in our case that does not work: We are still on non-Central AOS 8, and do not yet have plans or desire to move to Central with our wireless.
    So what is an adequate replacement of the 7205?
    The small 9004 and 9012 Controllers only have gigabit ports. The 9240 is a lot more expensive even without performance licenses. The 91xx seem to be Central only.
    Will there still be new hardware usable in a Conductor/Controller Cluster, or is it essentially dead now, considering that the 7xx Access Points are also Central only?
  • 2.  RE: Adequate replacement for 7205 Controller?
    Posted 22 days ago
    Depending on the size of the Installation you have the following options:
    9004 with up to 32 APs on a single Box
    9012 with up to 64 APs on a single Box (starting with AOS 8.12.x, all other Versions before do support up to 32 APs)
    9240 with up to 512 (Base) / 1024 (Silver) and 2048 (Gold) APs; for Silver / Gold you need to purchase the dedicated Capacity License
    Virtual Controllers scalable with up to 6000 APs (in steps of 10, 50, 250, 1000) on Hyper-V, KVM or ESXi
    With a Mobility Conductor you have the option to Cluster Controllers (4 x 90xx or vMCs / 12 x 9240) to get the designated Number of APs connected.
